S14 Digital Climate control! S14 to S14 Help Come on now guys, my USDM broke.
DaConfusion
Car: Nissan 240sx 1997
Ok guys my car was broken into and the *** who did it ruined most of the electronics so I have decided to take advantage and just put in a digital climate control. I havent found any new useful posts anywhere. There was one good one by s14boy but he never finished with install instructions.So i have done my search many times!
If you guys look you see the USDM climate control on the bottom and silvia on top. The USDM had 3 harness connectors, the white one went in the far left which prob controls the unit turning on and off. If you look on the siliva one theres a white hole... Is something supposed to go in there??? And does anyone have JDM/USDM wiring diagrams that can help me figure out which wires to match? I will be cutting and splicing if need be. Another observation, the 2 connectors on the right, one on the far right of the Sivlia fits the one on the left on the USDM.
Anand
Car: 95 Nissan 240SX
sorry man, this job is a solo project. you have to figure those out yourself.
all I know is from what I have heard and read..
but you need sensors, door motors and wiring harness off Q45/J30/Maxima
it will tkae you a long time to finish this project.
DaConfusion
Thanks for the info, its better than the usual insult and crap people who think they know everything say. Zilvia people just talk mess:"**And if you're basing anything off what you read on NICO, you might as well drop that 800hp RB in because it's a direct swap too, plugs right in, and only takes a few minutes. And the resistor in the AIT gives you 30hp, don't forget about that during the install."
thats messed up freakin trolls
98s14inaz
Car: 2010 Nissan Titan Quad Cab
Zilvia and FA have really lost their edge. Too many drift ricers that think they know it all. I looked into that mod at one point but it is not a simple plug and play. Because there aren't moving parts anymore you need the relays and motors from other digital cars to make that mod work. I am pretty sure it uses a vacuum source as well.
Bottom line, huge pain in the ***, cheaper to repair the USDM system, parts are easier to find for usdm system.
Just sell that thing on ebay and move on.
Almost forgot, next time you go to Zilvia tell them KA-T>RB ha ha good luck friend.
