DJButton wrote:Christine, the easiest way is going to be burning them out, like you would with subframe bushings. A press probably wouldn't want to move the age old rubber. Soak them down and torch them, it will probably take a few hours to burn it all out.
Hmm. Well they were kind of taken out and re-inserted before the install way back when the diff was put in. Have you or any of your buddies done S14 bushings before? I would imagine they are a little easier than doing subframe bushings (esp. the numbers I pointed out which are held together w/ washer and two big *** bolts).
If I have to get a torch then so be it, but I want to be absolutely sure.
