sigsterrr »
https://forums.nicoclub.com/sigsterrr-u157668.html
Sat Sep 11, 2010 5:26 pm
well replaced the fuel filter, which was dirty. Not any difference after a minute. Checked the maf and reads fine. Checked tps and reads fine. My check engine light doesnt work, but the ecu doesnt show codes when tested.
I am guessing fuel pump? Disconnected hose on fpr and no difference. I believe if you disconnect the vacuum line on the fpr (and block the vacuum line) the pressure goes up so I am guessing no problem there since there was no difference...
Input is welcome.
