S14 cranks but doesnt start ... fuel found on exhaust pipe!?!?
hakosuka86
Car: Toyotas Nissans
Hello, I have a 95 s14 i have a problem with the car starting, seems to much gas its being send since when i cranked it, there was a strong gas smell and so i went outside and notice fuel was dripping off the exhaust, how can I fix this problem??? Please help. thank you very much.
Fla240sx
timing/igntion problem
takes 3 things to start an engine
correct time of all related componentsignition sparkand of course fuel
since u have an abundance of fuel thats not the problem...
hakosuka86
THANK YOU VERY MUCH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Fla240sx
did u fix it? what ended up being the problem?
hakosuka86
oh It ended up being the head gasket and a bad injector just pouring gas.
do you think this is too much money for:Head gasket exhaust gasket windshieldinjector swapdistributor wire workinstall exhaust timing and fix smog 600$
Oh i have a question for you:My sunroof on the s14 doesnt move, I can hear the motor running but seems stuck, or is it something else.
thank you for your help!!
Fla240sx
thats a good price
how u sure the headgasket is popped?
hakosuka86
mmmm saw it.
the distributor wasnt sending signal either it was very weak. im getting another one too.
questionin my s13 it started doing this, I crank it and i have to press on the gas pedal so it turns on.it does this sum times, like today it turn on right away but once i go to store the car cranks and takes a while for it to start, then my idle its 1500rpm .must do idle adjustment , but do i need a new fuel pump?? or is it a vaccum leak?
