S14 conversion on S13
charlotte240
I know of a s14 in a junk yard that has been hit from the rear and wanted to know how hard this conversion is. Is it as straightforward as a s13-silvia conversion? I've heard that it "takes some work" but no one has ever gone into detail with that. Any help would be appreciated because my front end is pretty torn up and I can get this whole s14 pretty cheap (cheaper than replacing a stock s13).
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
i have seen it done (although i think the one i saw had aftermarket fenders and hood just like a S15 conversion)
Anand
Car: 95 Nissan 240SX
is it a S14a or s14b??? but as far as I know it would not look that great.. I have seen a picture of it and it didn't look right to me... but that's my .o2
NeedCAforS13
Car: CA swapped S13 coupe
I think it would be pretty sweet... are you talking about a 95-96 or 97-98 one? Either would be cool :) If you get it working and it looks good, its something I might try and look into for my car!
Sean
Flybert
What's up Anand? how's it goin? I didn't feel like making a whole post to say hello. I'd feel kinda weird. I just left a message on your phone right now.
As for that whole s14a or s14b. s14a=after s14b=before but for some people it is alphabetical order so it's not good to refer to it using those terms. It's better to use zenki and kouki s14 to be more specific.
I don't think S14 front ends look good on s13. If you're going to put a different s-chassis front end on an s13 go for the more round s15 because the lines match up better.
NeedCAforS13
Flybert wrote:If you're going to put a different s-chassis front end on an s13 go for the more round s15 because the lines match up better.
(not on the boxy coupe;))
Sean
leftovercrizack
NeedCAforS13 wrote:(not on the boxy coupe;))
Coupes are beautiful though, i <3 my coupe.
Flybert
but of course
NeedCAforS13
oh for sure! I LOVE! my coupe... no one knows what it is (outside the car scene of course;)) people always see the fastbacks, but the coupe is way rarer... plus it looks sportier, and the slimmer trunkline makes it appear smaller IMO:)
Sean
wpg240
Car: Hockey
I was under the impression that the S14 front end was slightly wider than the S13 requiring a fair bit of bodyshop massaging. Not something you can drag home and bolt on with a little adjusting.
charlotte240
It doesn't matter about what s14 front it is because they both have the same mounting points. I'm not really wanting to know about what you guys think about it. I want to know how hard it is.
wpg240, you are the closest to answering my question. lol, good job......... I just want to know how much "body massaging" is required and exactly what needs to be "massaged" so that I can decide if it's worth doing or not.
But for you other guys, it's a RPS13 and the donor is going to be a 95. I prefer the 97-98, but right now it's just an availability issue. Besides, I think the front on the 95 would match up pretty well with the rear of the hatch (as far as looks and "curviness") alot more than even the 89-91 stock front end.
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
i've never seen a zenki s14 front end on a S13 period...i think it'd be very cool, and also lots of originality points
Rockenreno
Car: 1997 BMW M3
MainEvent212 wrote:i've never seen a zenki s14 front end on a S13 period...i think it'd be very cool, and also lots of originality points
It would be very unique... and zenki's rock :)
I've heard it requires a lot of "massaging" as you put it
ride4lame
From what i have heard, you need special aftermarket fenders. The front end of the s14 is wider.Jspec.com sells the stuff you need to do it.
http://www.jspec.com/s14koukcon.html
deftdrummer
Car: cars, drums, music, technology
im not so sure the front end of the S13 would look so great if you did that. It just wouldn't flow. But then again you don't want my opinion. so here goes:
The S14 stock body is wider than the S13 by a good distance, if you were going to have it done i would highly recommend taking it to a very reputable body shop. Remember, if you have enough money...anything is possible.
charlotte240
so would it be possile to take some really thick sheet metal and make some strips or brackets to bolt to the s13 chasis and then have the s14 fenders bolt to the brackets? also, what about the front end? does that bolt up? custom headlight brackets? I'm wanting to basically know every detail about this conversion. Hell, maybe I'll make a sticky or a page about it.
deftdrummer
reason you have no info is because it would look ugly and so nobody does it. But if that's your thing then ok
ride4lame
There is a maroon one in Japan(s13 with S14a front)In my opnion it looks really good. But thats my opinion. I have the pic on my other computer at home...I will see if my littler sister can send it to me or something
