s14kouki »
https://forums.nicoclub.com/s14kouki-u12284.html
Wed Mar 14, 2007 3:14 pm
i dont know where you got i said there were two types pedal assembles for the S14, but i said the adjustment procedure is the same between s13 and s14, and that there pedals and master cylinders are diffrent between s13 and s14. You just made adjusting the clutch pedal a lot harder than it had to be.
First off loosen the bolt ii circled in red, then you will see that what i have circled in black is not completly smooth but has grooves in it, the grooves are there for gripping the rod with a set of pylers or something.
The part i have circled in blue is threaded, when you use the pylers to twist the rod it will either twist into the fork, putting more of the rod(threaded section) on the inside of the fork, or thread out, putting more of the threads outside the fork, towards the master cylinder.
Putting more threads on the outside, toward the master cylinder makes the clutch pedal put pressure on the MC, essentially pushing on the clutch pedal slightly, making the engagement point higher on the pedal, because in a sense you have already pushed on the pedal a bit and vice versa.
simple enough right?
