i need help i live in miami and its always raining around summer time but my a/c dose not work because of the clutch on the a.c compressor is stuck i disconnected the cable that powers up the compressor now my climate control won't work now i try to press any of the buttons and nothing works around the same time that i disconnected the wire for the commpresser i also cut a green wire that i had connected to a fan temp switch by flex a lite after i got rid of the temp switch now i wired up the fans to a relay i was told that the green wire was for the a/c fan dose the green wire stop the climate control from working
i reconnected the power wire to a new compresser and still dose not work ....dose not let any of the buttons work but lights up and the fan switch works what can it be and how can i fix this i need the help because my windows get really foggy and i cant drive like that down here in miami
can it beeeeeeeeeee its been 2 years already aaaaaaaaa i cant drive in the rain help meeeeeeeee iam going krazzy jk but dam man it sucks i need it fixed fast i will post a video if need to help me
