ddgsxr504 wrote:Its an aftermarket temp sensor, see how the wire runs thru the floor instead of towards the lower transmission harness.
that's what i said
Quote »when did nissan use a braided cover over the oxygen sensor wire?
the shiny straight test pipe that's polished to a high gloss gives it away[/quote]yes, OP, pull the ecu and access the codes thru the LEDs, reset the ecu, then drive around if the check engine light goes back on... repeat to make sure the ecu spit out the same code & go from there...
