piranhamatt »
https://forums.nicoclub.com/piranhamatt-u129770.html
Fri Mar 19, 2010 5:07 am
So I'm finally getting things going with my project. One of the first things I wanted to do was check the chain guides. Not surprisingly, they were in very poor shape.
Luckily, I anticipated this while at the junkyard over the winter. I was pulling late style injectors/rails from a Q when I decided I should probably grab the chain guides as well to save a little money.
Last night I installed the used guides from the junkyard, and realized that over the months I lost the bolts. I figured I would be able to use the old bolts; I was wrong. The old bolts do not fit into the new guides properly.
I searched a lot last night in an attempt to figure out which bolts I need, but came up empty handed. I found a list of timing parts many times, which included the required bolts. Does anyone know which ones I need from this list?
2x 01121-04711 - bolts for new guides4x 11051-60U04 - cam end seals2x 13021-60U00 - crank/cam sprockets2x 13028-60U00 - timing chains1x 13070-60U03 - chain tensioner(RH)1x 13070-60U12 - chain tensioner(LH)4x 13075-60U02 - tensioner bolts 1x 13079-60U01 - tensioner gasket(LH)2x 13085-60U01 - chain guide 2x 13085-60U11 - chain guide1x 13091-60U01 - guide(tension RH)1x 13091-60U11 - guide(tension LH)2x 13094-60U00 - guide bolts1x 13510-60U00 - front cover seal1x 15041-60U00 - oil pump chain1x 15043-60U00 - crank/timing sprocket1x 15044-60U00 - crank/oil sprocket1x 15072-60U00 - bracket oil pump1x 15073-60U00 - oil pump chain guide1x 15073-60U10 - oil pump chain guide2x 13270-60U00 - valve cover gaskets
Here's some show and tell with pictures:
^Old Guides
^New Guides (not fully secured because the bolts are wrong)
^Here's the very dirty VH. The headers were just test fitted here so I could measure some things.
^various VH build stuff
^Late style injectors/rails/harnesses
^Removal of sound deadening
^Z32 Trans
^Better shot of the car
^Rear end shot
Modified by piranhamatt at 11:44 AM 4/8/2010
Modified by piranhamatt at 12:23 PM 4/8/2010
