nightkid86 wrote:lets see some pics of the cutoff on a wall 20 ft away from your car. If it is a kit, then it is probably pretty bad and you are going to blind oncoming traffic. Retrofitting is the way to go.
yea, post pics!
my friend also has hid's in her kouki. the glare is actually not bad at all - SUV's behind you are still worse. aimed just slightly lower than stock, the stock glare shield does a decent job of keeping glare out. and the projector pattern does cut off the hid bulb pretty well.
my other friend installed s2k projectors into his kouki - and yes, that's the way to go. Relatively, it's WAY better, of course. But even just pop in the bulb into the kouki projector is still SIGNIFICANTLY better than an ebay h4 housing + hid kit install.
