s14 brakes
themeanest240
Car: 1991 240sx
i have d/s rotors in the front and the old stock rotors and callipers in the rear. few days ago i heard the rear brakes sqeeking dont know what to do hole new rotors and callipers or what?
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
First off this is in the wrong forum.... that's why we have one called "wheels, tires, brakes, and suspension"
Anyway if your back brakes are squeaking then it means the wear indicator is rubbing the rotor which is car code for change dem pads. If your rotors are within limits you can just get them turned, I however would get matching rotors to coincide with the fronts i.e. drilled and slotted. Your calipers are just fine, make sure you clean the outside of them really good with a wire brush to get all the road grime and caked on brake dust off of them.
Good Luck.
