s14 brakes on s13
tex240
i just bought an s13 hatch with no abs and it needs a brake job. i have some old 4 lug rotors and pads of my base s14 that didn't have abs either can i use any of it on the s13? thanks
s13sr20chris
s14 has bigger front brakes and will require more than just pads and rotors iirc.
tex240
damn i wish they would fit. if any one knows for sure that would be great.
slow s13
Car: cars, photo, music
they will fit just fine, s14's have the same brakes as 13's maybe in japan they where bigger but I made a quick check to be shure and buybrakes.com has the same rotor part numbers listed for both cars and beside if they where bigger all the s13 folks would be after s14 brakes
tex240
sweet thanks
s13sr20chris
s14 fronts= cl22vf rears= cl11h
s13 fronts= cl22vb(standard) cl25va(with abs)s13 rears= cl9h
ok, so i was wrong. i thought i remembered the s14 having the same fronts as the s13 abs model. incorrecto. now those suffixes(suffices?) may mean something important but i dont know. the number refers to the size(but i believe it is arbitrary).
Texas240
Car: '89 coupe, 90k. w/ agx's & h-tech's. K&N. & cat-back
why not the 300zx upgrade?
cdlong
Car: '95 240sx
because the s14 brakes are free. being new isn't an excuse for not reading.
