S14 battery relocation ground on manifold?
DMan II-40
Car: 1995 240SX SE
I was wondering if it matters if I remove the ground that connected the intake manifold to the battery? or should I ground the intake manifold to the body of the car now?
Couldn't find the answer to that one from searching. sry
rico05
Car: 1992 RMS13 w/ CA18DET
Run it from the mani to the chassis in some manner. If you don't, you will kill your battery. I did not replace that ground when I first moved my battery. Killed a nearly brand new stock replacement battery in about 2 miles. 'Twas no fun pushing it home...
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
That makes no sense, but some components might be picking a ground up on there so its good to have that jumper
n240sxfnatic
rico05 wrote:Run it from the mani to the chassis in some manner. If you don't, you will kill your battery.
I have only had my battery grounded to my car through (1) cable in the trunk, Never had a problem in 4 years.
DMan II-40
Car: 1995 240SX SE
Let me re-phrase this a little. I already have everything hooked up in the trunk and all is well. Relocation finished.
But there is a ground wire that ran from the intake manifold, to the battery (no longer there), and then to some other wires by the radiator. I'm wondering if I can remove that wire all together to try and clean things up a bit. I will take some pictures and post them up in a little while, but right now I'm out the door. Let me know what you guys think.
n240sxfnatic
There is 2 wires grounded below the battery tray. One goes to the intake manifold and one tho the - terminal. I ripped them out and havent ever had a problem. So yes, I would tear them out.
DMan II-40
Car: 1995 240SX SE
n240sxfnatic wrote:There is 2 wires grounded below the battery tray. One goes to the intake manifold and one tho the - terminal. I ripped them out and havent ever had a problem. So yes, I would tear them out.
cool, that's what I was looking for. Thanks
rico05
Well, I had the issue. I killed my battery, I then recharged it, added the ground and never had an issue again.
Besides, for the most efficency of the charging and ignition systems, you want as many grounds as possible. But you do as you please.
inertiaprojectCC
Car: 1993 240SX
I welded a bolt to the floor pan for my battery ground. Under the hood I welded another bolt to my strut tower and grounded the manifold ground to that. Worked like a charm man.
