AmoebAssassin »
https://forums.nicoclub.com/amoebassassin-u22213.html
Tue Jul 19, 2005 6:24 am
I agree on the coolant temp sensor. My s13 had the same problem as you two are describing. I checked everything important, EGR, plugs, injectors, IACV, etc. etc. However, i went to take apart the coolant temp sensor, and after just wiggling hte plug around the idle settled down perfectly at 700rpm, no balking, no stalling, no jumpy/hunting idle.
The reason that this happens is that an engine will inject more or less fuel (turning fuel compensations on and off) based on the temperature of the block. It gets this information via the coolant temp sensor and other accessory sensors. If your coolant temp sensor is sending info that is out of spec, the ECU will fall back on the intake air temp sensor, which is a FAR FAR FAR less accurate of engine temp than the coolant temp sensor. If the engine doesnt know which compensation setting to run at, you get plain crappy performance, poor fuel economy, stalling while decellerating in neutral, lumpy idle, and reluctance to rev.
I got lucky, my coolant temp sensor was still good, just the connectors had oxidized at their contact points. I didn't even have to dissasemble the plug, just a bit of movement in the connector scrubbed the contacts clean and solved my problem.
Take a multimeter to your coolant temp sensor when its cold and after it's run a bit. Compare the readings against the FSM spec values. It's nothing more than a thermocouple that delivers a resistance reading, so you can take multimeter readings when the car's off, so as to avoid being mangled by the close-by radiator fan.
If everything is in spec there, the next thing i'd do is let the engine run at idle with the air conditioner off. Pinch off the EGR vacuum line and see if the engine responds. If that checks out, unplug each injector on ONLY one cylinder at a time. The engine should stumble and shake more every time you unplug an injector. If this doesnt happen, or the effect is lesser on one of the cylinders, you could have fuel, spark, or compression woes on that cylinder. If this checks out, you need to take the IACV off the intake manifold and douse it in carb cleaner, reinstalling it with a new gasket. If this doesnt help, you're pretty SOL. Try a new ECU, or consult the FSM for more info and diagnostics.
