s14 backfire
tkoppab
Car: 1995 Nissan 240sx
i have a 95 s14 and for some reason whenever i let go of the gas, it back fires about 3 times, three spurts, any one have any idea why? has new plugs, and cables, help me out fellas. appreciate it.
Ligouri Rd
Car: '96 Nissan 240SX
Leaky injector maybe. Individually disconnect each injector from the wire harness. If the idle doesn't drop on one of em then it is pissing in fuel when its sposed to be closed. Replace that injector's o-rings or worst case the injector itself.
tkoppab
alright, i'm going to give it a shot and let you know what happens, hopefully it works
tkoppab
well it wasnt the injectors, tried out what you said, might be the cap and rotor not sure, just going to change em to make sure, any other suggestions?
s14touge
Car: 1995 240sx s14
you could be running rich. or your cat could be gutted. do you have exhaust?
tkoppab
yeah it has an aftermarket magnaflow performance exhaust.
Ligouri Rd
How severe is the backfire? Are we talking firecraker bang or just a little pop?Once I took out my cat (back when she was NA) I would get a string of little pops while decelerating in gear right as the engine neared about 1500rpm.
I doubt it has anything to due with the ignition system. Next thought would be primary O2 sensor or MAF since they directly control the fuel mixture. Mine went out at around 120k mi.
BoostedNismoNJ
Car: 1991 240sx
Sounds like the MAF or o2 sensors
Is it NA or boosted???
tkoppab
just stock engine and all, no boost, just a simple pop, nothing huge,
BoostedNismoNJ
Car: 1991 240sx
Is the Ecu throwing any codes?
tkoppab
didnt think about checking that, going to have to check that out too. any i should look out for that shouldnt be there?
