S14 Auto-X allignement question
sheadee240
Is the front camber adjustable on my S14. I thought that you only needed to buy an alignment kit if your car was slammed like 2 inches past the adjustment range of the factory suspension. Any ideas on a good AUTO-X setting for S14 with pro-Kit springs...I was thinking like 3 degrees negative camber all the way around, as my car is very well balanced as is. Another guy told me 4 degrees neg front and 3 deg. neg. in back. I thought that the camber was adjustable from the factory on both the front and back...Is this correct? The FAQ ALIGNEMENT says that the front is not adjustable, I don't know if this refers to the S14 as well as the S13?
THANKS in advance
Shea
daniel240
Car: cars/motocross
yea its adjustable but not much, to get those settings it will probably maxed out.
nismofan14
I would invest in a camber correction kit.......couple different brands and they aren't too much(I think). Plus in the installs page on 240sx.org there is step by step instructions on how to modify the stock parts to do the same. Hope that helps.
