kevinarich wrote:you have to trick the car in to thinking its in park, by jumping a couple wires at the fuse box under the hood. you need to run two wires from the neutral switch on the transmission, which is the one closest to the shifter to a pin on the Ecm and the other to ground. you dont have to worry about the 5th gear one. the reverse switch needs to be hooked up to the green and black wire coming off of the old inhibitor switch on the auto transmission. this will turn your back up lights on.
the CAS needs to be hooked up and you need the right ECM for this swap. its needs to be for your year car because the 96 is different from the 95 and the 97-98 is different from the 96.
You can take the auto drive line and use the yoke from your s13 and it will fit. thats what i did.
you dont need to buy a 20 dollar dvd to do this swap. thats why people started these forums in the first place. to help one another out, not make money.
Yeah, thanks for being the first one to actually help me out on this. We will be working on it today and I am hoping to take it for a test drive by Noon. I had already bought the Standard driveshaft, the guys working on the driveshaft couldn't figure anything out (We are doing this in school and most people either dont feel like doing it, realized that lifting trannies is heavy and walked away to do something else, or just dont know what they are doingand it take forever to get anything done. So it has taken the majority of the week). And I do think I will be putting the Neutral start from the S13 in the S14, just for that factory feel.
