S14 Auto to RB20/25 Stick?
96240inNOVA
Is it possible? Do RB20 or 25 front clips come with transmissions? If not, what would I need?
spec-v5150
96240inNOVA wrote:Is it possible? Do RB20 or 25 front clips come with transmissions? If not, what would I need?
A CLIP is the FRONT HALF of the car. transmission included
themadscientist
it is possible but in the case of the 25 be ready to modify the driveshaft. Get a full front cut, you will need some of the parts from the body.
mmdb
pertaining to the first question, so inorder to hook up all the manual stuff: clutch lines, pedal, master/slave cyclinders, and... i think that's it?? and then it would be complete?
spec-v5150
mmdb wrote:pertaining to the first question, so inorder to hook up all the manual stuff: clutch lines, pedal, master/slave cyclinders, and... i think that's it?? and then it would be complete?
WTF!!!! what did you just say
96240inNOVA
As a student of the English language, WHAT THE F$#K DID YOU JUST SAY?
mmdb
You dummies. He asked if the transmission on the front clips (given that they're manual clips) from the rb25det or rb20det, would everything be included to finish up the swap into an s14 or s13 chassis? There you go ingrish majors (fobs) :thinker
HotWIRED
you'll still need to source the clutch line and master clutch cylinder from the US 240, but the clip should have everything else you need for the auto to manual swap.
