churroboy »
https://forums.nicoclub.com/churroboy-u90995.html
Sat Mar 01, 2008 5:27 pm
Hows it going, to all those who have done this conversion, or to those whove inquired pricing, this is for you. After reading the various conversion write-ups, I was convinced to do the conversion myself since everyone said it cost them about $400 for parts without the transmission. But wait, not for me, it's come out so far to $1,238.00 with the transmission. And I am looking in Junkyards and Ebay!!!! How can I reduce costs!!!
This is what I got so far. Please let me know what I am spending toooo much on, thanks.
$300 5 speed OBDII s14 transmission junkyard, $250 for the s13, but I need s14$300 5 speed Driveshaft front and rear sections (this may differ if you have ABS/LSD)240sxmotoring.com$80 Flywheel (Manual, new or resurfaced) ebay$5 M/T flywheel bolts (A/T bolts are too short) autozone, junkyard$100 Clutch Kit (Clutch, Throwout bearing, Pressure Plate, alignment tool – ebay or autozone$50 Shifter assembly (plate, lower rubber boot, upper leather boot, finisher plate) ebay$100 5 speed Crossmember I cant find one!$54 Clutch Master cylinder ebay$29 Clutch Slave cylinder ebay$40 Clutch hardlines 240sxmotoring.com$? Clutch rubber line and dampener line (which you may want to remove anyways) cant find$170 Clutch pedal assembly 240sxmotoring.com$free Brake pedal, cut to fit free$5 Bellhousing bolts for a 5 speed bellhousing (some of the A/T bolts can be reused) autozone, junkyard$5 Bolts to hold Pressure Plate to Flywheel (same thread as bolts that hold shifter to transmission, but a tad shorter) autozone, junkyard
Total$1238.00 !!!! This is way too expensive just for parts.
Please let me know what parts I am spending too much money on, thanks.
Modified by churroboy at 10:12 PM 3/2/2008
Modified by churroboy at 3:05 PM 3/3/2008
