D1 guy wrote:Ok guys im looking for an lsd for my 97 240. I have found one with 80k on it, in very good condition. Its on a 95 240 SE auto. Is this a good one to buy or is the j30 stronger? I dont want a nismo, kaaz, or cusco b/c they say you have to change the rearend grease....lsd mix every 3k miles. Any ideas, thoughts, recommendations? Im open to all suggestions, I just want a reliable lsd thats not harsh and hard to maintain.
The vlsd from the 240 will be a direct swap. Depending on the year of the j30, you may also have to buy and swap its axles.
Other than the output shaft bolt pattern and gear ratio, those two differentials are practically the same.
Plus, you'll probably like the higher gearing of the j30 vlsd on a turbo car.
