S14 Auto --> 5sp Swap Q's
ImportIntelligence
Car: Big turbo's :)
Bewfore I get flamed, I searched for this stuff with no results. Here's my Q's:------------------Will the S13 Pedal Assy's ( Brake and Clutch ) work on a 1997 S14?
Do I need to get a manual trans drive shaft? If so can it be an S13 drive shaft?
Will the S13 Clutch line work on the S14 chassis?
Thanks in advance for the reply's.
SpeedFreak
yes to all 3 questions.
Aries
Car: LT1 240SS
SpeedFreak wrote:yes to all 3 questions.
*Nods in agreement*
HotWIRED
I believe the S13 are 2" shorter and the center bearing is on the wrong shaft, also if your S14 has ABS you need to get the ABS driveshafts. The S13 shaft is to the left. The one on the right is Skyline Shaft. SHAFTS If you use the clutch hard line from the S13 you need to get the S13 Master cylinder also.
ImportIntelligence
Car: Big turbo's :)
We are putting the S13 Sr20 in a S14 chassis and converting it from auto to 5 sp. So which drive shaft do we need? with and without ABS please.
