s14:anyone running 18x9.5(rear) 18x8.5(f)
wilfonzo
Car: s14
as title says with +35 offset on both.
-any fitment problems-reccomendations on tire sizes, i want stretch- overall opinions
Decker
Car: 2JZ S14
also curious.
emperor_lunchbox
Car: 91 240sx, 96 eclipse spyder, and 96 camaro z28 (For Sale)
are these the sport max wheels?
I was told a few times that you would need a spacer for the front, a pretty meaty spacer as well. I was thinking about getting these with a 30 mm spacer in the front and a 25 mm spacer for the rear.
In terms of tire sizes, I am gonna run a 215 all the way around.
naed240sx
Car: .....
emperor_lunchbox wrote:are these the sport max wheels?
A 215 on an 18x9.5 will never stay on the bead. That is a huge stretch.
emperor_lunchbox
I see 215's on 9's all the time. I don't think a half inch will be too much. I may end up going 225 anyway. I guess we will see.
naed240sx
Car: .....
emperor_lunchbox wrote:I see 215's on 9's all the time. I don't think a half inch will be too much. I may end up going 225 anyway. I guess we will see.
215 on a 9 is already a huge stretch. It won't fit safely on a 9.5, and it will look rediculous. We are also talking about 18s, which means a smaller sidewall, which makes the stretch even more difficult.
emperor_lunchbox
I can agree with that, most of the 9's I see with 215's are on a 17" rim.
I guess I will have to go 225 then. Oh well.
naed240sx
Car: .....
emperor_lunchbox wrote:I can agree with that, most of the 9's I see with 215's are on a 17" rim.
You seem so dissapointed. Why are you wanting such a crazy stretch anyways?
Here is 235 on a 17x9.
It's already enough of a stretch to give you some handling benefits. I wouldn't run smaller than a 235 on an 18x9.5.
scott240sx
Car: 97 240sx
i am running 225/40/18 on 18x8.5 and 255/35/18 on 18x9.5 and the offset is 33 in front and 38 in rear and i have to have a 5mm spacer in front to keep from hitting my coilovers but the back is good, wish i went lower though on the offset
nismofly
Car: 89 Nissan 240SX Hatch
buddy here runs 235 on his 18x9.5's...trust me its the thinnest id go
like dean said...why you want such a crazy stretch anyway? are you getting low enough offsets that you actually need them or something?
emperor_lunchbox
I guess my disappointment stems from improper information. I was told the best size for a stretch on a 9" rim is a 215. It doesn't seem like 215 is a that big of a stretch anyway, 215mm is like 8.5 inches, 1/2" stretch on either side. It doesn't seem crazy to me. I dont think my offsets are too crazy, they will be a +5 front and a + 10 rear. I may use a larger spacer in the rear.
hannibal
Car: Red Line to Glenmont
I like the pic of the S13 with 235 on 9" wheel. Do you know the offset of those wheels?
wilfonzo, the front will definitely need a spacer. Based on the clearance of x8 +35, you'll need a 15mm spacer or so.
naed240sx
Car: .....
IWannaS15 wrote:I like the pic of the S13 with 235 on 9" wheel. Do you know the offset of those wheels?
17x9+20.
-2 camber.
Decker
Car: 2JZ S14
how quickly do you go through tires dean?
Kouki Chick
Car: 1997 Nissan 240sx
Decent stretch will be 225/40 and 245/40 that was what I ran on the nismos with the same exact offsets, you can run 215's in the front without beading issues as stated before. As for spacers you will need atleast a 5mm but preferrably a 7mm spacer in the front and a small spacer in the rear to get a good looking offset.
Bluejayde
I am running that exact setup. I currently have stock suspension and it fits fine, but just barely. There isn't even room for a wheel weight on the inside of the front wheels.
I think the fit okay in the rear, I'd like to stick them out a bit more and roll/pull the fenders. Front I definately would like a spacer. I'm not going to buy coilovers since I only plan on daily driving it. But I think aftermarket dampers will fit fine, assuming the spring base plate is in the stock location. I don't remember tire sizes exactly, but they are stretched a little, just to make them even with the rim. I can check tomorrow if anyone still needs.
Here's some pics of the wheels, if you want to see what I mean about spacers.
