base9se »
https://forums.nicoclub.com/base9se-u15548.html
Sun Jun 13, 2004 5:54 pm
For the past week my '95 240sx has been having thermostat problems. Once the car is started and the A/C is on, the thermostat starts climbing to H in the gauge. The A/C is not blowing cold air at all when the thermostat is rising. It usually takes about 2-3 minutes for the thermostat to go back to normal. I took it to a shop and they couldn't figure out what was wrong with my car after keeping it for 2 days.
The first time this happened was when I changed my belts and hoses about 6 months ago. The coolant was flushed and changed with Prestone Antifreeze/Coolant 5/150 Extended Life 5 years or 150,000 miles. After re-installing everything back it and drove it around the block, it did the same thing as its doing now, heating up (for about 2-3 minutes) and then going straight back down to normal (after about 2-3 minutes in the high thermostat range). It only did it that one time and now it's doing it all over again. Anyways, could the coolant be the problem? If so, What coolant are you guys using or would recommend?
Also, a friend suggested that it might be a bad thermostat? How can I find out if it is? Is there a simple test to find out if its the thermostat or not?
Need help, any other ideas of what else it could be?
