itsRaine »
https://forums.nicoclub.com/itsraine-u9380.html
Sun Aug 08, 2004 7:20 am
Okay so my air conditioning blows air, but it's whatever air is outside (temperature-wise). Same with my heater. In other words, I have a basic fan - no heat when I need it, no cold when I need it. I tried recharging the R134a, but it didn't seem to do the trick. I took the dash out to check if all the air passage doors were moving, and all worked fine except for the "air mixture door" which was stuck in "heat" position. Nevertheless I get no heat. I don't want to blindly replace each part until I figure out a solution, unless there's like a checklist to run through in diagnosing A/C problems. I need my A/C and heater working, not just because it's so hot right now in SoCal, but in winter it can get pretty cold outside as well.
