okay ive read the relevent threads but there is a conflict of information here: im about to get my s13 running with an s14 head, the shop called and told me that there is no oil gallery to get oil to a gear bushing on the front of the engine (?)apparently on the s13 they are copper and require lubrication and the s14's dont have this issue?
going from one thread here, it says you should use the s13 valve and front timing covers. the other says use s14. so which is it to be able to run oil to this area with no leaks? im confused :P
i need an answer for the shop asap so i can get my car back. what front cover/valve cover do i need? is there anything else i should know about getting my car back together? any knowledge would be appreciated, as long as it correct!
Modified by d!ck at 4:11 PM 10/28/2005
