s14 95 bolt on turbo greddy
rivetapproved240
Car: mechanical work
question, did a little research on the website regarding bolt on turbos for a 95 240sx se. GReddy makes a bolt on kit for a 96 ka24de but not for a 95. Will the turbo made for the 96 fit my 95 with little or no fabrication, and if fabrication is needed what kind?
SR20S14
I beleive that it would be the same as if it was a 96..I belive the motor setup is the same..not sure though..i'm sure somebody can verify
pinoysurf
Im pretty sure the difference is with the computer that comes with the Greddy. Its set for the OBD II. '96 and up. The turbo and everything else will fit fine you will just need to re-program the computer.
SilviaS14KA24DE
Car: Doriftu
shat. My 95 is OBD I i believe, because it only has one wire from the o2 sensor.
Putang ina Pinoy tarantado!
C-Kwik
http://www.nissaninfiniticlub....64084
SilviaS14KA24DE
Car: Doriftu
cool it works! I called a few months ago and they said it'll be carb legal in 3-6 months
civiceater
putangina rin!!! swerte ka may kit kang mabibili!!! (pinoy)
(what i said: sob too!!! you're lucky you guys have a kit that you can buy)
