?? I am not swapping the motor, I bought the car with 81,000 miles on the stock motor.jam1231 wrote:i plan on doing a swap on my 92 but i am having a bit of a time getting a motor where did yoou get yours?
yea, the stock ECu will work, i'm not using the 5-speed wiring harness either, im just going to hardwire the reverse lights and i'm not sure about the speed sensor.Dittoz7 wrote:Using The Same ECU?
Can't Wait Till Mine.
Nah, it's rebuilt...The seals are great. Yea the flywheel will be resurfaced.diggles240 wrote:Looks like fun... No new front/rear trans. seals or rear main seal planned? Resurface the flywheel. Good luck.
yep, and as an added bonus, you won't have a speed limiter anymore with that set updrifter92 wrote:
I think its because OBD l. I don't think they have CAS's but the OBDll transmissions do. Someone correct me if i'm wrongyoung-gunn wrote:thats weird, without the CAS I never got a CEL at all. my car was built in early 94 though...
i240sx wrote:i need this swap badly......
I already said we finished it...everything is good.OutToWinPAHC wrote:Tomorrow was 2 days ago, did you get it swapped.
It was around $1000 with a $300 Driveshaftshaft Shop Steel 1-Piece.shift_240 wrote:yeh can you post pics after the swap. how much total did you pay for everything if you dont mind? this is my next project once i get some cash together. looking good tho
