float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Mon Nov 12, 2007 8:52 pm
I've searched but nothing I've read seems to cover this particular aspect of the process.
First off, some backround. I have an S13, w/S14 spindles and ball joint. Its lacks ABS. I just purchased an S14 that is 4 lug but has ABS (LSD and a spoiler, but not sunroof. Weird *** car).
I was going to simply take the 5 lug front hubs from the S13 (remember it's got S14 spindles on it) and put them on the S14. The problem is that they don't have the gear for the ABS sensor. Now unless I'm looking at it wrong, that gear is pressed onto the front hub, so if I take the non-abs, 5 lug hub and try to put in on my ABS equipped S14, the ABS won't work because it lacks the gear.
Am I looking at it wrong and the gear isn't attached to the hub? If so that simplifies things. If not, does it come off and I can just put it on the 5 lug hub?
Does this make any sense at all? I feel like a newb...
