AustinSilvia »
https://forums.nicoclub.com/austinsilvia-u13268.html
Sat Jun 05, 2004 9:42 pm
it's not worth the trouble... you need to do a lot of wriing to make it work... but if you are gung ho about it here's what you need... the amp with both of the wiring harness things and the cd player with it's wiring harness things... you should just clip them at the ends with enough to solder more wires on there and enough to see the wire color and such so you can match the wires up... it shouldn't be too hard but man for the time and effort i would definitely go for some type of better upgrade. there are head units out there with much better amplifiers built in... less hastle, better sound and tuning capabilities and no crazt wiring jobs. trust me on this... it is much more worth the effort.
