S14/300ZX Brakes
puerkone
Car: 1989 Nissan 240SX SE-R
Just wondering is there a difference between both calipers? I have an S14 with 5 lug and 4 piston calipers for the front and 2 piston calipers for the rear. I looked at the 300ZX calipers and both look at the same size and length just that the 300zx calipers have nissan logo and the S14 calipers do not.
Modified by puerkone at 11:19 AM 2/2/2009
Philipio
Car: 96 240sx, 96 Miata
puerkone
are the 300ZX 5 lug rotors bigger than the S14 5 lug rotors? are they the same size? both are 5 lug right?
Philipio
The link I posted is very informative, you should read it.
"The front brakes start out as a 9.8" vented rotor and single piston caliper. The 300ZX offers an 11" rotor with a massive 4-piston caliper."
"The rear brakes start out as a 10.2" non vented rotor with a single piston caliper. Upgrading to the 300ZX equipment awards you with an 11.6" vented rotor with a separate drum e-brake and a 2 pistons caliper."
And yes, both are 5 lug.
supratt1001
Car: 96 240sx se
big diff
puerkone
http://my240.epijunkie.com/5_L...rsion
http://www.240sxforums.com/for....html
I am still a little confused/ I have S14 hubs, what year and model should I get the 4 piston calipers for the front and rear? also I cant use my S14 oem ebrake cable?
