S14 240SX auto nearly stalls/erratic idle after hard stops
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
just got my gfs S14 240SX back from the shop after 3 months (S15 front end :D) and we have a problem
engine runs fine, but when you come to a quick stop (braking firmly) the car nearly stalls, the engine bucks and then the car searches for idle 800-1200 rpm 800-1200 rpm.... then returns to normal
if it happened all the time I'd say it was for sure a vacuum leak but it only happens during hard stops
I cleaned the TB tonite, and there was no change anyone have any ideas on what it could be so I can start out early tomorrow?
thanks everyone
NISTECH
maybe trans shift related?
get up some speed throw it in nuetral and make a similar hard stop and see if it hunts for an idle then.
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1995 240SX S14.5
1995 240SX S14
1972 BMW 2002
1972 BMW E9
NISTECH wrote:maybe trans shift related?
it only hunts when the transmission is in gear. in neutral it idles like a champ
its wierd because the transmission started to slip today too doesnt do it all the time just once in awhile its kinda confusing
thing that bothers me is the bodsy shop left the hood of the car off while it was raining a few weeks ago... since then there are electrical gremlins everywhere
this being the most serious issue
NISTECH
check your connectors for the trans on the right fender well. see if they are holding water.
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1995 240SX S14.5
1995 240SX S14
1972 BMW 2002
1972 BMW E9
ok I'm doing that now
it definitely is a trans shift problem I can feel the trans shift when the car comes to a hard stop its really wierd
any other suggestions? I'll be back up in an hour to read them
need to get this car finished ASAP ehehehe
thanks!
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1995 240SX S14.5
1995 240SX S14
1972 BMW 2002
1972 BMW E9
fixed the problem with adding transmission fluid ad cleaning the harnesses.... probably more with th e transmission fluid I think haha it still read ok on the dipstick but I filled it to the top and the problem went away... so problem solved :D
NISTECH
you do know to check the trans fluid with the car running right??
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1995 240SX S14.5
1995 240SX S14
1972 BMW 2002
1972 BMW E9
NISTECH wrote:you do know to check the trans fluid with the car running right??
yup run it through the gears yup i did that...
i didnt do it before though :oface :icesangel
