s14 240 missing only when its hot!!!???
autox615
Car: 1995 Nissan 240sx
Hey guys I need some help, I've searched. Its a s14 obd1 240sx. It runs perfect when its cold and up until its up to temp. Its not throwing a code. The only things I have replaced is the fuel filter, and spark plus. The distributor cap, rotor button, and wires have been replaced in the last 15,000 miles. I also took off the distributor cap and cleaned the carbon buildup off the rotor points and rotor button.Thanks for the help!
the car has 210,000 miles on it but has been kept up, has great compression, and runs perfect ther than the freaking miss!)
180fan
Car: 89 fastback
check over the resistances in the ignition wires, and have you checked out your cts yet?
autox615
Well it doesnt matter anymore. I blew a head gasket yesterday, so im going to do a full rebuild now. thanks for the help!
matt4pl
Car: cars, anything fast, graphic design, lots of stuff
had a similar issue, turned out to be the CAS
