s14 232/232 cams vs s13 240/248 cams
brage
Well I dyno'd at intense a couple weeks back using the stock 95+ 232/232 cam setup. My peak at 89* ambient temp was 291 HP @ 20psi. on friday night I swapped in the 91 240/248 cams and it put down 314 HP @ 20psi with ambient temp of 106*!!!
the 291 dyno with 232/232 cams:
the 314 dyno with 240/248 cams:
klattr1
Car: GT42R powered S14/KA
congrats!
Redline240
Car: 95 240sx
That's one sick gain! How hard is it to find 91 cams in decent shape? How much do they usually go for?
Redline
Redline240
Car: 95 240sx
Just noticed the low torque numbers, any particular reason for that?
Redline
Drift Machine
Car: 1991 KA-T 240sx
Damn nice.
brage
Redline240 wrote:Just noticed the low torque numbers, any particular reason for that?
Redline
It was 106* out hehe.. but it seems that oithers have similar #s with low compression KAs running the same setup as me (fmax etc) klattr is also running the ross pistons in his motor with the f-max setup and he does 350tq w/ 392 HP so I'm seeing a similar tq to HP ratio...
Sucks, but hey I don't really care it makes 314 whp :D
hannibal
Car: Red Line to Glenmont
whats your setup if you dont mind spilling the beans??
BTW, Awesome gain from the cams. I wonder what kinda gains we would see on a T3/T4 8psi setup??
brage
IWannaS15 wrote:whats your setup if you dont mind spilling the beans??
probably a somewhat linear gain... NA i think it picks up 5-6 hp just about all the way across the power band..
I have f-max stg IIt3/t04bcobra maf50# injectorswalbro pumpmodified SR SS DP, catco high flow cat, Apexi N1 cbacktial 7psi WG, boost controlled by profec b spec II
motor is a 96 block with ross pistons .020 over and pauter rods with the rotating assembly balanced. I assembled the motor myself.
Stock '97 head with 38k mi on it...
uh thats about all that is relevant to this thread ;)
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Is that the same dyno? (EDIT: I mean the same dynojet...)
If not, why?
- Brian
klattr1
Redline
well, if you look at his graph, the peak tq on his graph isnt really where it should be in his powerband. This is prolly from fuel reasons. It probably jumps from somewhat optimal or leaner air fuel ratios to pig rich during that transition. That is the reason why my dyno has lower tq numbers compared to my horsepower (390rwhp vs. 352ft.lbs). My torque is a straight line across at the top of the curve so it really never has a peak point.
chandler
Car: 91 civic hb & 96 S14
I got soem s13 cams, make me an offer, I wont be needin them any time soon, just lost my job, cant mod the ride any for a while =(
brage
:: orion :: wrote:Is that the same dyno? (EDIT: I mean the same dynojet...)
If not, why?
- Brian
the first sheet was on a dynojet at intense motorsports, where I got the actual .drf file and that jpg is an export from winpep on my computer. The second sheet is from ADC (arizona dyno chip) and was on the same model dynojet.
Both were on dyno days.... when I dyno at intense next time I will post if anything changes, but the two dynos should be pretty consistent.
-jeff
Structure240sx
what was your afr's during the runs? i have a simialr turbo if not the same. im trying to see just how much it sucks.
huguetpj
Car: 93 KAT Coupe
brage wrote:the first sheet was on a dynojet at intense motorsports, where I got the actual .drf file and that jpg is an export from winpep on my computer. The second sheet is from ADC (arizona dyno chip) and was on the same model dynojet.
That alone could account for some differences... either pro or con
brage
huguetpj wrote:That alone could account for some differences... either pro or con
I agree, I plan to go back to the same dyno when I get a chance to.
brage
-jeff
Quite rich... running the JWT 50#/cobra maf program. I lost my log of the runs... I have a pretty bad exhaust leak right now and the dynoject afr wasn't reading correctly.
I have a WB in the car, and I relied on that..
My A/Fs on the high end are in the 10:1 region. Next time I dyno IU will be putting the dyno O2 in my DP!!!
-Jeff
brage
OH!!! and if you decide to use the '91 cams in a 96/97/98 head, you need to kbock the oil gallery plugs at the rear of the cams in past the last journal! otherwise you'll have oil everywhere out your valve cover breather, etc...
96/97/98 heads don't have that last cam tower.
deezlins
Car: 95 240SX SE
brage wrote:96/97/98 heads don't have that last cam tower.
do the 95's?
turtl631
Car: S14
probably not, sounds like an OBDII thing
:: orion ::
'96 does...'97-98 are the only ones without that last tower.
Why...? Who knows...has nothing to do with emissions.
- Brian
fiznat
Car: Grown up :(
sorry to dredge this back up, but are the S13 cam durations all the same, or do they differ from year to year? (on just the DOHC models)...
nonchalant rage
Car: s12
he's using 91 cams, if thats what your question is. thats the only year the cams are like that.
Smurf6x6
Car: 93 CA18 Coupe
All S13 DOHC cams are the same.
hannibal
FSM says all 91-94 are 240/248
:: orion ::
nonchalant rage wrote:...thats the only year the cams are like that.
IWannaS15 wrote:FSM says all 91-94 are 240/248
smurf6x6 wrote:All S13 DOHC cams are the same.
^^^ All are kinda right...
'91 and '92 ALL had the 240/248 cams.
The FSM for '93-94 is incorrect.
In '93, they took away the seconday butterflies and changed cams, somewhere in that mnodel year. If you have secondary butterlfies on your '93 intake manifold, you have 240/248 cams.No secondary buttflies, then you have 232/232 cams, like S14s.
ALL '94s had the 232/232 setup (and no butterflies).
And I have a 240/248 set for sale, from a '92 = $120 shipped - [email protected]
[/shameless plug]
- Brian
98s14inaz
Car: 2010 Nissan Titan Quad Cab
Yes, I have a 95 head on my 98 s14. I am running the s13 240 248 cams with out any issues.
