S14 1995 cluster problem
JF240
Hi,I have a 240sx 1995 and the problem is that my rpm on the cluster is dead, the needle is dead she do not even move. I would like to know if somebody have already get this problem. Somebody know how to know if it is the cluster or the rpm sensor that is broken because I dont want to buy a other cluster for nothing, thank you
JF240
Can somebody know where is the tach sensor in the motor, and which wire I have to conect for a new tachometer.
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
I have no idea but I have a cluster I can sell you for $50 U.S.
nuts510
Car: sr20det 95 240sx, rb20det 93 240sx convertible, 78 280z turbo, 71 ca18det datsun 510, 72 scout,88 CR
they make it interesting on the 95 and up cars the Coil is inside the distributor and you want a hook your tack up the negative side. I would just fix the factory tack and a good used tack or there are several places that can rebuild your existing gauge I don't know how many tac's and speedometers I have replaced to those cars now but its been quite a few.
JF240
Thank you,So this mean that it is my cluster the problem and I should repair it, or it is the sensor in the distributor? also can I know if the rpm in hertz coming to my cluster with a multimeter?
