chmercer »
https://forums.nicoclub.com/chmercer-u5648.html
Sat Feb 12, 2005 6:44 pm
with a 235 on a 9 it will put a mild stretch on the tire in the front, gives it more fender clearance than a 245 on an 8, which would be much more of a ballooned sidewall. also, i run 14x8 wheels 0 offset with a 195/65, no problems. granted the fenders are rolled and light pull but there is no rubbing or anything. so lower offsets are quite possible to run on an s14 with stock modified fenders, for sure.
bottom line - if you want the wheels, get them, if they rub, make them fit. personally, i think you will be ok, might need a roll job depending on camber. but if you want the wheels on your car, make them go on
