Yeah i was thinking 225/40 in the front on a 17x9+15 because my car is a little low, would i rub with 45 series up front ?? would the 40 's be safer ? thanx for the info.. so 235 40"s up front and 255 40 's rear would not rub with just rolled fenders??nismofly wrote:you could fit 235/255 also if you wanted
better bet up front would be 225/45 if you wanted 225/245, then you run 245/40 in rear to match OD's
