s13sr20chris »
https://forums.nicoclub.com/s13sr20chris-u7880.html
Sat Dec 18, 2004 5:09 am
shoot bro, i just looked in the fsm at the knock sensor and found it is not where i thought it was. i thought i remembered it being by the oil pressure sending unit and the pcv valve. its not, its in a really bad spot. i think removing the manifold may be the way to go. if the method in that link works then thats great but i can tell you now that it would be hard to do. if it was mine, i would try to get something else to drive or get a day off from work. then i would get the intake manifold gaskets, pcv valve, knock sensor, harness(btw, i thought the harness had to be soldered but i was wrong, i now see its a plug in deal, can you tell i dont see too many s14's in the shop?), and some various hose stock and such. then i would yank the manifold and try to do as much stuff as i could while the manifold was off. thats just me, i like to fix stuff that aint broke.
