s13 wont start
CODYs13
Car: s13 coupe
I just swapped from a ka to a ka, but im having problems starting the car. When i try to start the car all i hear is a click and also im thinking i have a bad ground or something because my rpms will start going crazy. I tried tapping the starter but no luck.
If anyone one has any ideas or suggestions i would like to hear them.
thank you
p.s. im not sure if i posted in the right section
xX RB Xx
Car: SE3P, FC3S, FC3C.
sounds like your starter is dead or it is not hooked up right.
nismoracingsx
Car: 1993 White 240sx Coupe
agree, swap starters from the old engine see if the symptoms change..
also make sure all of your grounds/battery cables are hooked up correctly.
