comatoseculture »
https://forums.nicoclub.com/comatoseculture-u118100.html
Sat Aug 22, 2009 1:43 pm
Should be a clear picture of the relay, located by the battery tray, all the way at the front, close to the bumper, on the passenger fender (under the hood though). Hope that helps...
I should briefly mention my situation as well, in my case I checked the battery for voltage, but not under load. It had been starting slowly, then slower and slower then nothing. then clicking. multiple clicks. As the above posts mentioned, one click starter, more clicks battery, it was true in my case. I didn't read this yet tho...so i jumped the starter relay, swapped starters, checked my ignition cylinder, all before I did the following quick test...
Quick test was to have someone turn over the car as I checked to battery voltage (post to post, DC voltage) and my battery was dropping to 5 volts under the load of attempting to start the car. I should also mention that otherwise it showed 13.6volts or something, and as people have mentioned, the lights inside and accessories worked fine.
So, long story short, it's worth checking your battery under load if you have a friend and a voltmeter, and starter problems.
Modified by comatoseculture at 4:50 PM 8/22/2009
