S13 with WORKs..
johnny butt
Car: 1993 240sx Convertible
I'm thinking about picking up a set of Work (CR KAI) wheels for my S13. I have 5 lug converted already and have been looking at the 5x114 options, and was wondering what you guys' opinions are about wheel size, wheel width, preferred offset front & rear, and what tires size(s) i should match up to them?
I was thinking ~ 17 inches, and maybe a staggered set.
Something like:17x8 +32 (?) front,17x8.5 +37(?) or +30(?) rear ?
But wasn't sure about the offsets or what size of tires I should use? Looking for recommendations.
Or if you guys thought 8" will be too wide, and I should do 7" and 7.5" ?
Also, I have fully adjustable suspension (spl arms all around) with the exception of front and rear lower control arms. I am also using Stance GR + Pro coilovers, so adjusting for proper fitment shouldn't be a problem, I am looking for suggestions about what would look and work best.
Thanks.
Modified by johnny butt at 11:46 AM 12/10/2009
Modified by johnny butt at 12:20 PM 12/10/2009
simmode1
Car: Red '95 S14
johnny butt wrote:Or if you guys thought 8" will be too wide, and I should do 7" and 7.5" ?
Double Facepalm to you sir.
Go learn about good 240 wheel fitment before you waste your money.http://www.rimtuck.com/thumbna...l=S13&
Gabes13
Car: rb20det s13
Lolz @ 7"8" or wider with these cars. Fortunately, The wider the wheels the more concave with these wheels too (taking offset into consideration of course)Which apparently is the new hype.
After 5 mins of searching here.
What are you looking for?Max tire or Wheel fitment?
johnny butt
I've seen all of these pictures before and they are what turned me to the works to begin with. The four I left are the ones closest to what I am looking for. Now i know none of them are similar, but if I had to pick a favorite:
I am looking more fore fitment, I don't want to have to roll, tuck, or do anything really aggressive. I just want some clean looking wheels that will fit right.
Gabes13
Car: rb20det s13
17x8 +25 Front 17x9+28 Rear
with 225/45 tires and you're done.
johnny butt
would this be closer to 17x9.0 17mm offset all around? this one is starting to grow on me.
twinspoool
Car: S14 zenki
if you don't want to roll pull or anything like that then stick with hondas or such.. this is the nissans roll pull/wide body ftw
Gabes13
Car: rb20det s13
those are staggered 17s up front 18s back.
johnny butt
twinspoool wrote:if you don't want to roll pull or anything like that then stick with hondas or such.. this is the nissans roll pull/wide body ftw
hahahah, build a real car then i might consider taking things you say seriously. The widest rims I'm available to fit don't mean s*** to me if I can't corner quickly. This is an Auto-X / DD oriented car in which I probably have more $$ tied up in suspension & braking components than you do with your car and motor combined. Not trying to be a d!ck, but I don't need that s*** in this thread.
pandapants wrote:those are staggered 17s up front 18s back.
Thanks again for your help. I think I am going to stick with:FRONT: 17 x 9.0 +17 235 / 40 REAR: 17 x 9.0 +17 245 / 45
and hopefully that will give me my full turning radius.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
A good rule of thumb.
Dont run anything more than +18
Width should never be less than 8" Id say 9-10 inches wide is good it does not mean your tires need to be that wide.
