Bluefire wrote:
you can use a JDM S13 speedo thats reads up to 240kph and use the pot on the back to adjust to mph. I've done this on 2 cars and they both work perfectly. This works only on S13's with RB25's where the factory speedo reads slow. i have some JDM speedos as well, if anyone needs them...
Its because the Tach is made for an inline 4 and not the inline 6 its reading for... thus making it count roughly 1.5times high.
Neejay wrote:
I just turned the pot on the back of mine last night (all the way left to start out). I won't be able to plug it in until today though. I'll have to splice my speed wire from the ecu with my turbo timer, and use that to calibrate it.
Confirmed! I turned the pot all the way clockwise and tinkered with it a back and forth until i read about 850 RPM... took it for a drive... what do you know rev limiter hits at just the right spot. (I dont have anything fancy to test it with... but id say the RPM is +/- 100rpm. Judging by the smooth steady idle in the right spot and the rev limiter hitting right where it should...)
