boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Fri Jan 23, 2004 9:34 am
Quote »I have a pulsar with a ca18det,[/quote] If someone has swapped a CA18DET into your pulsar, why would you want to take it out to put into RWD 240? It would be a headache and you'd have to source brackets, P/S pump and A/C compressor to suit the RWD configuration. If soneone swapped a CA18ET into an S13 240 then that would be a waste as well, when they could've purchased the CA18DET to put in there. The CA18ET isn't a bad motor, but I personally wouldn't mess with it for big performance. I say scrap the CA18ET and get another CA18DET for your 240, if I had read your post correctly.
Dee
