rb250sx »
https://forums.nicoclub.com/rb250sx-u8777.html
Sun Oct 17, 2004 1:18 pm
well, i almost finished the wiring, but the problem was that the harness was initially chopped up for an s14 b4 i ever got it, so some parts are really confusing me, but when following the 8 steps just to get this thing running i ran into a little problem. The large plug that you are supposed to run to the starter signal wire didnt look right. for starters the black and white wire in the writeup appears to be black and red, and there is nothing running into its pin on the other side. I looked at the pin diagram and the ignition signal or something pin 45 if i remember right had a thin blue and yellow wire leading out of it that was not connected to any plug(from when the harness was made for the s14) . i took pictures of the plug on both sides, and was hoping someone could tell me where the other side of the pin is supposed to run to, or if im looking at the completely wrong wire.
side with the connector i cut off of the fuse box
side leading back to the ecu
any help would be appreciated.
