S13 Wiring issues/concerns VH-45 swap
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
DRFTBLD
Car: 89 S13 VH45DETT
05 Ford F-150 Drift Support
91 S13 Tester
08 Ford Focus
I'm doing some work on a 1992 240sx S13 Coupe. However it appears that the wiring harness is from a 1989 240sx. So I was working on the wiring and found that some of the wires don't exactly line up with the way they should be.
So I have redone the file from SuperHatch and would like some input on it. Some of the wires line up and others I think I got lined up but can you guys take a look and see what your thoughts are.
The file can be found at this link since I can't attach them in here.
http://www.v8nissans.com/forums/showthr ... s-concerns
JSimpson21
Car: '97 SRVE
'90 450sx
The wiring between all S13s is the exact same, just the dash plug is a different color and style. The pins on both dash plugs are identical.
DRFTBLD
91 S13 Tester
08 Ford Focus
can you explain further? I'm looking at the 92 and 89 wires in hand right now and the plugs are the same, the colors are different.
Return to “VH45DE / VK45DE / VK56DE Forum”
