obarrera wrote:Sorry, searching is a little hard, I never find specific answers to any questions I might have.
I was looking at these wheels http://phase2motorsports.store....html I think it's a pretty good price, I want atleast 18" wheels, but cosidering the price, I might go with 17's, if I want some 18/19" deep dish wheels I would have to do the 5 lug conversion right?
If I go with the ones I linked, they would cost me a little over $660.00, plus like $400.00 for tires, that's $1,060, plus the rear cambers you mentioned, they probably cost arounf what, $390.00 I don't really know.
That would be around $1,450, plus what I spend on lowring the car..please let me know if im missing something?
wow... you've got a lot of learning to do.
damn... I dont even know where to start.
1) if you wan't that kind of stance, you'll either need coilovers and rear upper control arms... or you can just get coilovers and play your luck and just slam the car with it (the suspension geometry negates the camber when lowered. The lower you go, the more negative camber you'll get). Lowering springs and struts won't get near that kind of stance. Coilovers alone will cost you from $800-1000+ (depending on brand). Rear upper control arms can cost $180+ (depending on brand)
2) those wheels that you linked are NOT deep lipped. Frankly, they're bootlegs of the SSR SP1 professors. You want something deep and similarly styled... get some Work Meister S1's in a super gangster offset. Ofcourse, you get a wider selection of wheels when you go 5 lug tho... (unless you buy brand new from the manufacturer, then the option is yours)
3) you'll need fender work to fit such agressive profile (note the fender). Same car btw...
Theres really no easy way through it, I mean, I can try tell you specific specs and you can just write it down on a peice of paper, then go to youre local JDM store and see if the parts guy can read your hand writing..
or
you can just start out slow and one by one. Start out by getting your supension squared away.
oh, and unless you have uber hook-ups on products, a $2000 budget might not cut it
Just my .02
