Exar-Kun wrote:the 16x7.5 is a great wheel, allowing a 225-50-16 nice sticky tire, get the something below a 35mm offset and it should be fine, a better choice would be a 30mm or 27mm offset...-chet
Don't want to post a new thread, so i'll just post a follow-up to your reply Exar.
I plan to go with 16" rims, i believe they are the most versatile rims over 15's because of tires choice, and streetability. Therefore, my question being what offset i should go for with a 16x7 rim? I want to go to the widest width i can go in the rear, (225) is what i've been told i could go. But the Rota Circuit 8's that i'm lusting over are a 40 " offset. Bad, good?
(Oh, I am adding z32 26mm brakes up front shortly. )
mmm..circuit 8's
