Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Tue Dec 21, 2004 1:42 pm
Handles great......
compared to?
seriously now...do you honestly think ANY of us can out engineer a japanese suspension designer? I don't think so. If you can, please let me know, I need to get some questions about a road race setup answered.
OTHERWISE, what dori and smithsr said is right. Keeping the wheel in propper offset and width will make the car handle better and more predictably, increase treadwear (which, by the way..even treadwear means the tires contact patch has better utilization...) and keep you from screwing with sensitive things that most people here don't have any business messing with:-scrub radious, kingpin inclinations, front to rear wheel centerline differentiation, suspension alignment/geometry(more than just the readings folks..the frame/arm interaction) etc, etc...
Sure if you want to be a mad-tight drifter or whatever, you may not give a damned about those things..you just want it to look a certain way, and since your main goal is to smoke the crap out of a tire anyways..true static traction and other things don't really matter, much less hub stress, etc...
If so, please just say "I want to make it look cool with big/wide wheels"
We'll be more than happy to tell you howto screw up the engineering that some of Japans finest engineers put into your car-just so you can look cool.seriously.
-Chet
