doubledashdrifting »
https://forums.nicoclub.com/doubledashdrifting-u58175.html
Wed Oct 22, 2008 10:54 am
Well I've had this sound for a bit and cannot locate it. I've already searched but have had no luck with the same type of whine.
The whine almost sounds like a small supercharger, very high pitched and increases with rpm. It will happen in neutral and in any gear, most noticed in 1st gear. It will start as soon as the engine starts but only when I bring up the rpms so don't think its the oil pump, no set rpm it happens throughout the rpm range. I thought it might be my alternator over charging because it sounds like its coming from the front of the motor almost at the crank pulley. BUT, I can hear it with the hood closed while driving so I'm not 100% sure. My clutch is slipping right now and getting it replaced on Saturday along with new flywheel.
The car still pulls hard except the clutch slipping, but motor is strong. It has gotten a little louder since i first heard it and I'm at a stand still as to what the heck it is. Any help would be awesome.
