S13 w/s15sr
Msregor
Car: 91 240sx s15 sr20det
Hi, I've been on here for a while but only to get help through other users experiences. Wanted to post my car and get some advice on an issue I'm having.
91 240sx
s15 sr
kouki ecu and wire harness coil packs ect
tomei 7960 turbo kit
ex power chrome ceramic coated manifold
circuit sports oval d/p (moonpie style )
stance water neck spacer
black coated water necks and turbo elbow
tomei proncams
tomei coil pack cover
tomei fpr with matching gauge
nismo motor mounts
tomei style oil pan
circuit sports rocket arm stoppers
all new gaskets
custom shaved and polished intake manifold
tomei oil cap
aeromotive fuel pump
era 72mm black tb
aem air filter
polised charge pipe
cx racing ic kit
tial bov black
pbm skid plate
touge factory valve cover nuts
kazama oil catch can
nissan oem fan shroud
cx racing radiator
isis rad hoses
isis power steering line
full -an ,fuel system, oil catch can, power steering
6 speed s15 transmission
nismo lightweight flywheel
braided clutch line
exedy stage 2 clutch
dss 1pc drive shaft
s15 rear diff welded
cody ace a/c brackets
compressor lines and drier evaportor new o rings
all lines near turbo have been wrapped with defi heat sleeve or gold heat tape including a/c lines
brakes
z32 front and rear caliper
z32 e brake and cables
z32 master cylinder
slotted and drilled front rotors
braided lines
new ac delco rear rotors
brake master heat plate
suspension
k sport pro coils
braced and boxed power brace
pbm tension rods
rear toe and ruca
modded rear subframe
pbm pro knuckles
energry suspension rack bushings
Interior
new black carpet (front and rear)
clean dash one crack has devopled over the steering wheel but cant be seen
nardi deep corn wheel white spoke red stitch
boss hub
led cluster lights
greddy shifter knob
led dome light
buddyclub wide driver seat
nasgia rails
prosport boost and water temp halo gauge
hks gauge holder
aem wideband
jvc head unit
polk speakers
stainless battery bracket
shell
oem type x skirts
wing
front bumper
fpr rear valences and front lip
type x tails with lower trim
clear square and fender lights
east bear mirrors
freshly painted shell. was painted last year and has a couple nics from being in the garage and being worked on and small ping in the front fender and a mark on the drive rear quater but nothing noticeable really
clear headlight housing
hid
Can't find how to attach pics.
So my issue is the vct. Pretty sure it's the culprit. Does the knocking at idle once warmed up. Non existent at 1200rpm. Sometimes it'll make the noise at one stop light but not the next. Haven't done a compression test. Bogs a tiny bit coming to a stop (atmospheric bov).Also fuel pressure doesn't hold once primed. Other than that, the cars runs great. Pulls hard. Af ratios are good and so is vac (sits at 19). Any suggestions would be greatly appreciated.
PapaSmurf2k3
Site Admin
You might want to refine your mod list to things that are germane to your issue. I don't think east bear mirrors have anything to do with an engine knock/tap.
I'd suggest doing a compression check, and oil pressure check.
Msregor
I said, "I wanted to post my car.". Also, I thought I posted to the "I'm new and I have a simple question" thread.
240sx general discussion
General discussion forum about the
240sx, and a great place to introduce
yourself to the board!
Thanks for the help. I'll do what you suggested.
