S13 w/Redtop Swap: No Power At All
pwrofdrm
I'm currently swapping a Redtop SR20DET (bought complete swap from jdmenginedepot.com) into my 1990 240SX coupe. The car was a running and driving original car that's never been tampered with, I purchased it from the original owner bone stock. I'm the only one that's ever worked on the car before now, and it's a good friend who is a mechanic helping me with the swap.
I have just about everything wrapped up...fuel pump, wiring, engine is in, front mount, wires that needed to be extended are done, I swapped in a tach from a DOHC, looped the powersteering, removed A/C, boost gauge, electric fan, and relocated the battery to the back. Wiring was performed as per frsport.com .
Today I put the battery in the box and hooked up the terminals and put the key to the on position, and nothing happened. No dash lights, no interior lights, no fuel pump priming, the terminals didn't even spark when I put them on. I hooked the battery up to a charger (the real plug in kind, not one of those portable ones) and still nothing.
So I played with it for a bit, moved the ground to the battery, cleaned it up good, nothing. I know the power cable wasn't shorting anywhere because it didn't spark, but just in case I moved the battery back to the front of the car and tried again. Still nothing.
So, has anyone ever been in my shoes before? Is there a ground I'm overlooking, fuses I should be looking for, or could I have done some of the wiring incorrectly? Is there even a wire in the plugs that I modified (as per frsport.com) that could possibly cause this?
TIA, I tried searching and the FAQ's and didn't come up with spit.
onosqv
Car: '92 240sx Vert
Elminate one thing @ a time... From you saying battery box, sounds like you did a relocation?
If you did, temporarily move the battery back to the front & hook it up there - of course, voltimeter to make sure the battery is holding a charge.
If it works, then you know it's the relocation that is bad, if it doesn't, then you are missing some major grounds somewhere.
Regardless of what you did w/ the engine, once the battery is in, basic things like interior lights & headlights, etc should be working.
CMG
Car: 1989 240sx Hatch w/ Redtop
Something screwy with the battery relocation obviously.
pwrofdrm
One of the last things I did before I called it a night was move the battery back up front. I thought maybe the battery wire I ran was grounding out possibly.
Wasn't the case, as it still doesn't do anything. I spoke to a few people and I'm gonna have a go at it again tonight.
onosqv
Car: '92 240sx Vert
That could still be the case - check your fuse box in the engine compartment & driver side kick panel, also - one of those could have blown w/ the relocation setup.
Again, regardless of whether or not you have an engine hooked up, the basic stuff should still be working: i.e. interior/exterior lights, etc.
pwrofdrm
Long story short, when you do your battery relocation kit, make sure you run power to all the wires which were previously attached to the positive battery terminal
